A hand-held "dustbuster" style vacuum by AEG-Electrolux.
2 Questions View all
Showing it is charging, but no powder. Does not switch on.?
no power when switched on
Add a comment
1 Answer
Chosen Solution
Denice Terink, Find below a disassembly guide link that you can use to disassemble the hand vac. and test/inspect switch/components with a DVOM to determine if bad, check wires/connections for being loose/burnt /broken, test replace batteries if not holding a charge. Also check charger contacts for corrosion/damage and check charger out put with DVOM to see that it is in deed working. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
AEG Electrolux FM72 Disassembly for cleaning
Score 2
Add a comment
Add your answer
Denice Terink will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 99
