Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Questions View all
It is restarting continuously due to network.
I've been using it for a year and then I started to use net in it after a day when I turn on data screen flikers and screen get frozen and it restarts so it goes on until I put it on airplane mode! But after an update it doesn't even turning on for a second and starts again and just get froze on choose your language and restarts ! What to do? Is it hardware problem? Or else. Plz help!!
One more thing it was working fine before update without sin after an update it just restarts! U can also tell me is there any way to put it on airplane mode so I just can use if without sim.
1 Comment
Ya before an update I can toggle it into airplane mode but after updating it,it just keep restarting and yes, sometime it vibrates twice. No, it's due to the battery it's because of network I think coz when I use it on airplane mode if works fine and when I disable it screen flikers and it froze and just keep restarting!
by
Add a comment
1 Answer
Chosen Solution
You can toggle airplane mode on and off using the power menu via holding power button while on.
You may need to reflash the Samsung Firmware on the phone to fix this issue. Is it that shut down (vibrate multiple times) then restart issue?
How to flash samsung firmware onto phone:
http://updato.com/how-to/how-to-install-...
If all of the above don't work - Try another battery sounds like the battery has gone bad.
I know that a lot of Samsung devices have screen flicker when the battery is like 0% or under normal battery voltage <3.7V.
Score 2
Add a comment
Add your answer
Manish Tomar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,725
