Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4418 Questions View all
iPhone 6 wont turn on after screen replacement
Hi,
Just replaced my iphone 6 screen but the device no longer turns on. The device however connects to my computer.
Any ideas what I might have done? or a fix.
Thanks
Comments:
Did you remove the battery before removing any connectors? Are you sure all connectors are plugged in properly?
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Hi,
Did you disconnect the battery before removing and connecting the new screen? If not, you may have blown the backlight, unfortunately this would need someone who can microlsder to repair the issue.
Or, you may have purchased a faulty part, try another screen and see if that resolves your issue. :-)
Score 1
Add a comment
Add your answer
iamqwerty will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 47
