Hot point Fridge frezzer not cooling
My hot point fridge freezer was not cooling and after I took the inside panel off there was cool air coming in to the fridge, I jammed open the electronic damper to find that my freezer then froze every thing. Thinking this was the problem I replaced it but it still does not work. Any ideas please.
Add a comment
Most Helpful Answer
Cause 1
Condenser Coils are Dirty
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won’t dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty—if the condenser coils are dirty, clean them.
Cause 2
Condenser Fan Motor
The condenser fan motor draws air though the condenser coils and over the compressor. If the condenser fan motor is not working properly, the refrigerator won’t cool properly. To determine if the fan motor is defective, first check the fan blade for obstructions. Next, try turning the fan motor blade by hand. If the blade does not spin freely, replace the condenser fan motor. If no obstructions are present and the fan blade spins freely, use a multimeter to test the fan motor for continuity. If the condenser fan motor does not have continuity, replace it.
Cause 3
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Score 2
Add a comment
Steven-the electronic damper opens an closes for refrigerator section temperature control. Keeping it open will cause your refrigerator to be as cold as your freezer.
Is the evaporator fan running? Located behind the back freezer panel. The panel comes off exposing evaporator coils. If those are frozen solid no air will flow.
Score 2
3 Comments:
Hi, I have taken the panel off inside the freezer and the fan is not moving but I can spin it freely by hand.
by
Sorry a bit too quick to answer the fan is working.
by
Stephen, did you notice any ice build up one the evaporator coils in the freezer near the evaporator motor?
Is the food in freezer staying frozen? Freezer temp should be 0*. Fresh food 36*
You mentioned you replaced a part, what part was it?
Could you provide the model number? It is on a sticker inside the fresh food section about eye level. Thanks.
by
Add a comment
Add your answer
stephen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 146
