The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3723 Questions View all
The home button won't click or work
I have just replace the screen for my iPhone 5s and the home button won't work or click when I put the screen back to normal but when. I have it out it clicks and it works
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
Try this first, bend the metal plate behind the home button outwards so the metal plate is further away from the home button.
Check for any glue residue in the home button hole (on the screen) also check if the home button itself is clean from dust / grime / debris.
Try loosening the two screws for the home button metal plate holder like TY said.
22 hours ago by Ben
Add a comment
Greeting Miz! Is the EMI shield over your home button on upside down? If it's clicking when it's open but not when it's closed it could be that. The sheild had a little extension (it looks like a chimney on a house when it's right side up) that needs to be pointing upward not downwards yes. Let me know if this helps (:
Comments:
It is pointing the right way i don't know what's wrong but I need it fixed
by
When the device is closed does the home button make the clicking sound at all? If not your screws might be on a little too tight.
by
Nope it doesn't when it's on it and I press it it's too deep it doesn't click
by
by
You where correct I bent it and it worked
by
Show 3 more comments
Add a comment
Add your answer
Miz Mercado will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 109
All Time: 2,393
