Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
After I replaced my charging port, it turns on but doesn't charge
My iPhone 5s recently didn't want to charge so i decided to change the charging port, I carefully followed each and every step to replace the port and followed the guide on ifixit.com. After completion I came upon a error, I plugged in the device with a new charger and then the device turned on like normal, however, once the devices lock screen appeared the lightning bolt next to the battery didn't appear, IT WASN'T CHARGING. I don't know what could have happened or what I should do to fix this.
Add a comment
1 Answer
Chosen Solution
Have you tried another charging cable and wall charger after replacing the charging port? Did you make sure that the charging port assembly is fully against the housing?
It does sound like a faulty charging dock assembly though.
Score 2
Add a comment
Add your answer
johndiaz693 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 73
