The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 Questions View all
blue light then popping noise
Hi,
I brought a faulty 2ds thinking it'd be an easy fix.
I opened it up, checked all the ribbons and they all seem well seated, tried the wifi card & I still get the pop noise.
I looked at the screens with some light & they appear to have some cracks, I haven't taken the motherboard off yet.
Any ideas on how to fix it?
Also, on opening the gate on the home button ribbon I pulled off the grey gate, should it operate fine without it?
Thanks.
Add a comment
1 Answer
Usually breaking the ribbon cable latches is bad, but i don't think the home button should be that bad (try applying pressure while booting). Sometimes components fail without you being able to see (my n3dsxl wouldn't boot because of a non-working screen -no cracks, no rips in the cable), so consider getting a 2ds for parts, so you can test what's wrong with it.
Add a comment
Add your answer
Jack will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 854
