Boost signal on my wi-fi
How can I boost my signal in my house it will not pick up in the upper far guess bedroom
You might want to read up on mesh networks: The Best Wi-Fi Mesh-Networking Kits for Most People
Also keep in mind the WiFi frequency you are using also plays a part in this. 2.4 GHz goes farther but is slower than 5.0 GHz. Using either a mesh or extender will use what it can connect to the base. To make this work you often need a few remotes (mesh) to get the full bandwidth of the 5.0 GHz band.
Clearly your other alternative here is to extend your wired network if you can route the wire between your base Router to the more distant location you wish to connect into. Then, place a second WiFi router at this location.
Install a WiFi signal extender. https://www.amazon.ca/s/?ie=UTF8&keyword...
Hope this helps
I just use a tin can and a piece of wire haha
@gigabit87898 Its hard to to make the corners with the can and string but on a straight shot it cant be beat ;-)
Thanks very helpful
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 60
1 Comment
Thanks will order 1 today any recommendations
by Kevin mac
