The touch not responding after changing the digitizer
I have replaced my Samsung Galaxy S Duos digitizer. After some days the touch is automatically goes to different apps or its not responding properly to touch.
Hi,
Could be a few things:
- The replacement part could be faulty.
- You haven't placed the connector in correctly.
- You may have damaged the connector or something else inside the phone.
- Cheap part.
- You may also have damaged the replacement part if you bent/crimped the cable too much.
I would suggest reopening the device, checking all connections and then test again.
If that doesn't solve your issue, try get another replacement part, as you may have got a faulty part.
Check for any damage to the logic board.
Hope this helps. :-)
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 66
1 Comment
Where did you get the digitizer from? How much did you pay? Are you sure all the connections are plugged in properly?
by Cameron
