Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
550 Questions View all
Why will my blade not stop running after switch is off?
PTO will not turn blades off, blade will stop after shutting mower off. Is there another piece in this system that needs replacement or adjusting?
Add a comment
1 Answer
Chosen Solution
@chipfish, Chip, It sounds like either a faulty switch(unplug and test switch for no continuity when off) or the PTO clutch itself is sticking(bad bearing possibly), unplug the wire on the PTO clutch, with the spark plugs disconnected have an assistant turn over the engine while you look at the belt on the PTO, If belt is spinning or trying to spin the PTO clutch is faulty. Link below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://forums2.gardenweb.com/discussions...
Score 1
Add a comment
Add your answer
Chip fiske will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 79
All Time: 941
