Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
929 Questions View all
Installed a HDD in optical bay, but then primary SSD wouldn't work...
After trying a few configurations, I currently have my SSD, (which works fine, tested externally and internally) installed in the optical bay and a HDD in the hard drive bay. The HDD works briefly and then disconnects/ejects, I wasn't accessing when it does this.
I have read that running the OS from the optical bay isn't ideal so I want to move it to the hard drive bay, which doesn't seem to want to read it.
Does this sound like I damage the hard drive cable?
Comments:
Please tell us about the drives. Have you ever replaced the HD/IR cable?
by
Most likely your HD drive cable is worn out as Mayer pointed out but you could also have a second issue here. I would also review the notes in OWC's product: OWC Data Doubler. It makes no difference who's device you used the issue is within the MacBook its self.
by
It was the hard drive cable - new one installed and it seems to be working fine.
Had some minor booting issues as both drives had a Recovery partition and it didn't like that. Deleted the partition from the secondary drive and boots as it should.
Thanks Everyone!
by
Add a comment
1 Answer
Chosen Solution
yes it is ur cable problem
check it
Score 2
Comments:
I ordered a new Hard Drive Cable, will try that. I don't think any of the issues on the OWC site pertain to my system. Thanks for the suggestions. I'll post the results.
Also, wanted to comment to anyone adding in a data doubler, watch/be prepared for brittle plastic on the subwoofer. :(
by
Add a comment
Add your answer
Paul Taylor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 29
