Fourth generation Samsung Android tablets. Released in April 2014.
359 Questions View all
Tablet discharge within a few minutes some times.
Sometimes it takes hours to load the tablet completly and it even discharge while atached to the charging cable.
Add a comment
Chosen Solution
Replacing the battery should fix the discharge problem. Luckily, ifixit sells it.
Galaxy Tab 4 10.1 Battery
However, if it doesn't charge well even after the battery replacement, your charging port/cable is bad or your charger isn't powerful enough. First, get a brand new Samsung cable. Not a flimsy one you would get at a convenience store. Also, make sure your charger is at least 2.1A 5v. If neither of those fix it, you'll have to replace the charge port.
Hope this helps!
Nexus 9 AC Power Adapter and Charging Cable
Galaxy Tab 4 10.1 Battery Image
Product
$24.99
Nexus 9 AC Power Adapter and Charging Cable Image
Product
$12.99
Score 2
Add a comment
Are you using the original charger?
1 Comment:
Yes, I also tried another one and the same result.
But it doesnt happend every time.
by
Add a comment
Add your answer
Paul Matho will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 828
