one off logic board nut broken.
there is anyway how to fix these problem ,my phone wont turn on. I can't recovery my pictures even when I plug it to pc I can't put my password black screen .
thank you.
thank you.
How was this standoff broken? Was it because you tightened the screw too much and it broke off?
You may have severely damaged your logic board as there are copper traces that run beneath that standoff and they can be damaged by putting in a longer screw or breaking the standoff. This is called Long-Screw Damage.
This would require a micro-soldering repair so you will need to find a reputable shop that does this.
Minho thanks for the reply .
please do u know where to buy that standoff brass. the one is broken.
You probably don't need it, the other screws should secure the bracket sufficiently. However, the easiest way is to get one from a donor logic board. Otherwise I would look on aliexpress.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 636
