Wireless not working on sony vaio
My wireless button is not working and when I go on Windows Mobility Center the wireless picture does not come what can I do to make it work.
Ithank you in advance for the help!
hassan go into the device manage and find Network adapters open it and then select the controller open it and go to drivers update drivers . This will reload the affected driver . If this brings no joy then there is possibly a problem with the NIC .To test this open the command prompts and type ping 127.0.0.1 If your NIC is working properly then you should get reply from 127.0.0.1 in the ping stats there should be 0% loss. if not then it may be time for a new WiFi card . You can also try flushing the DNS while your in the command prompts this will help with that https://www.whatsmydns.net/flush-dns.htm.... Hope this helps
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 6,052
