Any thoughts on the tune-up on my iMac?
imac 21.5" late 2013 EMC 2638 Mod. No. A1418
I am bored, of waiting 17 hours for my iMac to render a 5 minute animation, to the point I get irritated and thought it would be a great idea to tune my iMac a bit so I ordered:
1. One 1Tb Samsung EVO M.2 SSD
2. One 1Tb Samsung EVO 850 SATA SSD
3. Two 8Gb DDR3 SO-DIMM 1600MHz
Any thoughts before I recieve the stuff?
I can return them or some of them if they aren´t compitable but as far as I can see they are compitable, but just in case I throw out the question.
More then happy for any kind of answeres!
Thank you in advance!
Update (05/09/2017)
Hi, Dan!
Thank you for taking the time to give me your thoughts.
If I understood you right it goes like this:
The M.2 SSD wont fit so that´s that.
However the 2.5" SSD fits but I have to tear down the screen and so on.
And the 16 RAM will fit but I have to tear down the screen.
I have ordered not only the memories but also the necessary tools for doing it exactly like it says here on how to HDD to SSD and also how to switch RAMs, I am not a novice with opening and chaning parts in computers but this far I never did it on a mac but I understand the steps and will have the correct and necessary tools and I don´t think it will be any issue since I am careful and gentle with my hands.
So The 2.5" SSD and the RAMs are getting switched, BUT, I still want to put an M.2 type of SSD if it´s possible and on iMac Intel 21.5" EMC 2638 Blade SSD Replacement they say it is for the models with 2.9GHz and 2.7GHz like mine with EMC2638 and a i5 and the next step i7 is EMC 2742 which the switching will also work on... my question here is:
Is it or is it not possiblble to put both the 2.5" and M.2 just that I have the wrong M.2 which wont fit?
If it is possible please show me what M.2 type of memory that fits.
Dan I´m sorry if you already answered this question and I didn´t get it but I wont open my imac before I´m 100% sure that I have not only the correct parts but also the correct equipment tools etc. because this is my baby and as with my other children I only want what´s best for them, not taking any unecessary risks that I would regret.
Thank you every all of you for taking your time to just write how great Dan is and so on, it makes me feel just about home with you guys!
And again Dan, if you have a little more time to spare please help me a little bit further.
Update (05/09/2017)
So I get the point why the EVO 960 won't work so now I´m searching without any luck so far a PCIe Gen3. or 4. (that fits the EVO) to Thunderbolt adaptor so I still will be able to use the awesome speeds it´s capable of, anyone know about one of those adaptors or another way to use the EVO at optimal or near optimal speeds?
Thankfull eternally for answers!
Update (05/10/2017)
Dan,
so I should just replace the i5 with a Intel Core i7 4790K 4,0 GHz LGA1150 with multithreads and the fat lady will sing?
Update (05/10/2017)
well of course I want the MacPro with all extras and therefore I just want to have a small unit not very expensive but that goes fast enough to make the money to go get my MacPro.
With MacPro I will have a computer that reaches further into the bag with all my needs, I hope anyway, I will find the limitations on that onsoon enoug but I hope not too fast, not like the one I have that needs 70 hours to render a not-even-good -looking-5-minute-visual, I haven't even started with C4D yet because It will go even slower and slower than 70h/5 min is not acceptable and havent been for at least the last 70 hours, real-time rendering, whatever I do, have all the programs I´m running on simultaneoulsy working on detalis for the bigpic, but not with this one I have it´s like there was only one employee at The iLoop...
30 Comments
Because this got pushed back. @danj what do you have to say?
by Cameron
Your systems specs: iMac 21.5" 2.7 GHz i5 (Late 2013)
by Dan
@acaciainferis - Your system supports two drives a 2.5" SATA III and a custom Apple blade SSD. Again the Samsung M.2 SSD (or any other M.2 SSD) will not work in your system!
The biggest custom Apple PCIe blade SSD's you can find online that will work in your system are these:
- iMac 128GB Solid State Drive, Late 2013 / Mid 2014
- iMac 256GB Solid State Drive, Late 2013 / Mid 2014
You'll need to use an external Thunderbolt 2 RAID system if you want something larger thats as fast
by Dan
I still think after you plug everything in you won't get as much processing punch as you are expecting here. I strongly recommend getting a i7 system and work from there.
You might want to hold off a bit as well as Apple has pre-announced some more powerful iMac's are coming out this fall. Here's a bit more: What's Next for the iMac
We use MacPro's for our video editing because they offer still more threads to crunch things than the iMac i5/i7 CPU's can. In our case MacPro's Xeon 12, 16 or 24 threads) Just to give you an idea what the pro's use.
by Dan
Here's a deeper explanation on multi-core & CPU/GPU threading: How Do CPUs Use Multiple Cores? Linus does a good job explaining things here.
by Dan
Show 25 more comments
