Display doesn't work after LCD replacement
The LCD of my phone was damaged because of water. Everything else was working fine because I can slide my figure on the screen and can see effect(very little because of damaged LCD). I opened the iphone (front panel) and now i have 3 piece (front glass, LCD and back panel). Then I connected the #3 cable to make sure that LCD is bad and I can see that LCD was not working. So I ordered the lcd. And I kept the phone in the ziplock to make sure that I don't loose anything. I got the LCD in a week and before I put everything back again, I wanted to make sure that the lcd is good so I did the same thing. Put the #3 cable of new lcd but iphone didn't display anything so I placed #3 of my old LCD it still didn't display anything.
hmm then I place 1,2,3 all the cables back (old lcd) , phone still didn't display anything.
But itune is picking up phone, alarm is working (it started beeping 6am so i know), as soon as I charge i hear the noise u get when u plug charging cable..
Anything idea what could be wrong, how to fix it????
2 Comments
You only damaged the LCD with water? No other damage? Could it be that you had more damage to the phone and while you were waiting on your new LCD you ended up with corrosion? Did you make sure that all contacts are clean and free of corrosion.
by oldturkey03
Yes only LCD was damaged. I cannot see any other damage. The phone was damaged almost 2 months back and I ordered the new LCD only a week back so whatever damage would have happened , would have happened long back.
by am43210
