Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Possible logic board failure on iPhone 6 Plus
Randomly this evening my iPhone 6 Plus decided to end its existence in some sense. It was working perfectly fine prior to me going outside for a smoke. I came back inside and the screen had gone black and the back light was turning on and off repeatedly. I initiated a hard reset because the power button was not responsive and after that there was nothing. I plugged it into my PC to see if anything could be done in iTunes but it required me to enter the password from the phone that was dead. I tried forcing it into recovery mode but that needed a password as well. The phone obviously turns on and off when using the hard reset but nothing works. The vibrate switch is unresponsive as well. Touch ID to unlock the phone doesn't work because the PIN needs to be entered when the phone is turned back on. Wondering what you guys think these symptoms add up to. Feedback will be much appreciated. Also the phone was in perfect condition previous the this, and I have had it since the first day it was released. EDIT: Right now just trying to let the battery drain to see if I can revive it with a fresh charge (wishful thinking I know) I am now noticing there is a pretty warm spot on the phone just under the camera
Score 1
1 Comment
Mine has had the same issue just stop working...Could be the motherboard
by
Add a comment
1 Answer
Chosen Solution
Assuming the phone wasn't dropped or water damaged in the days leading up to the failure, you probably have a defective screen or modular component.
If you are comfortable opening your device (follow this guide) then I would suggest you disconnect the front camera flex to see if this helps. Always disconnect the battery first (and connect it last) and be very gentle; flexes and connectors are very fragile.
If this solves your problem, then order a replacement Front Camera flex. If not then it may be screen or logic board related. With the phone "on", try shining a bright flashlight on the screen. You may see a dim image, which would be indicative of a failed backlight circuit on the logic board. If there is no dim image, then it is most likely a defective screen.
The problem with troubleshooting the screen is that you need a known-good replacement screen. The other option is to bring it to a reputable repair shop.
Score 3
Add a comment
Add your answer
Spencer Ludwig will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 21,426
