It's just dead, no reason.
So I got this phone in a lot of phones. It's been plugged in for the last hour and is completely dead. I have a battery, not sure if it works, but it fits and is the correct Pinout. What should I try?
Score 1
Add a comment
1 Answer
Most Helpful Answer
1-check battery using multimeter (voltage should be around 3.8~3.7 on DCV range)
2-if battery is not as mentioned above connect it to a power supply rated at 3.8v (+to+ & -to-) for about 1 min then measure its voltage again.
3-if battery voltage increased then it is ok and accepting charging but it was flat dead.
4-if not then battery is damaged and need replacement.
you can also try another procedure as follows:
1-plug your charger in wall outlet, don't connect its usb to your phone yet.
2-press and hold power button
3-while like that....plug in charger usb to phone socket
4-release power button on sight of starting screen
Score 2
Comments:
Thanks, I will try this tomorrow.
by
No dice- still dead.
by
Add a comment
Add your answer
Gigabit87898 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 48
