How to change keyboard and CPU fan
my cpu fan and keyboard failure
Hi @nursarif ,
Here is a link to the service manual for your laptop.
Keyboard.
Scroll to p.49 to view the necessary pre-requisites and then the procedure to remove/replace the keyboard in the laptop.
Scroll to p.108-109 to view the part numbers for the keyboard in your laptop. As the keyboard is country specific you will need to ascertain which exact keyboard you need. The part number should be printed on your keyboard which should be of some help. Once you have found the correct part number, search online using just the part number only - nothing else to find suppliers of the part that suit you best.
Fan.
Scroll to p.74 to view the necessary pre-requisites and then the procedure to remove/replace the fan assembly in the laptop.
Scroll to p.101 to view the part numbers for the fan in your laptop, (item #12 either the complete fan/thermal assembly or just the fan). You will need to ascertain which exact fan that you need. The part number should be printed on the fan assembly which should be of some help. Once you have found the correct part number, search online using just the part number only - nothing else to find suppliers of the part that suit you best.
Hopefully this is of some help.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 184
