Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
There are black and white lines appear on my iPhone 6.
I took off the screen and then I put them back together again, thereafter I power on the black and white lines appear from top to the bottom of the screen.
Add a comment
Chosen Solution
So if you can't get it back to working normal, after disconnecting battery and reseating the connections and reconnecting the battery, the display is likely damaged, and you'll need to get a new one. It's on the outside, but you can try cleaning the sockets on the logic board and socket connectors on the display assembly, with 90% or higher isopropyl alcohol. Kind of a far reach though
iPhone 6 Screen Replacement
iPhone 6 Screen
iPhone 6 Screen Image
Product
iPhone 6 Screen
$44.99
Score 3
Add a comment
Most Helpful Answer
You must not have seat the LCD cable properly. Just open it back up, flip up the lock, wipe off the contacts, put it back in lock it and put the screen back.
Hope this helps!
Score 3
8 Comments:
Hey congratulations on the 5k your half way there
by
Thanks @jimfixer. I'm working hard to help others, with your help.
by
Oh, yeah. Look at you go, lil bro. You'll hit that 10k in no time!
by
Just reviewed a bunch of your answers and bumped you another hundred
by
That's a good idea @jimfixer
by
Show 3 more comments
Add a comment
Add your answer
Alvin Loo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 3,224
