Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
83 Questions View all
3DS won't turn on, charging light turns off after a few seconds
Okay so my friend gave me this busted New 3DS (the non-XL model) and we fixed it except for one part, and I ended up frying the button board by being lazy and putting the battery in backwards while avoiding closing the case all the way to test it. I replaced it, everything worked fine, then I gave up on fixing the HOME button, and pulled out the foam I had been using to try to push the ribbon cable clasp down. As soon as I did that, it stopped turning on, and I'm getting the same symptoms as when I had fried the button board: power button doesn't do anything, charging light turns on but doesn't stay on for more than a few seconds. Battery had been fully charged when it had been charging.
It can't be that I fried the board again, I didn't do anything that could have done that. I'm not sure where to test it with my multimeter to see if I did blow a fuse somehow.
1 Comment
Hi, I also have his problem. What can I do? I replaced the top screen and I reassembled the device, connected EVERYTHING and it did not want to power on anymore but the orange light stays forever.
by
Add a comment
1 Answer
Most Helpful Answer
If you placed the battery with wrong polarity you blow one the power line fuses (F1 or F2).
Just replace it and it will be 100% functional.
Regards,
Juan
Score 1
1 Comment:
Where are those fuses located? They don't seem to be labeled.
The thing is, I blew the fuse on my old board, then replaced it. I didn't put the battery in wrong with this one, and I did nothing between it working and not working that would have blown a fuse, as far as I know. I'd like to confirm that a fuse got blown somehow before I go buy a second replacement one of these.
by
Add a comment
Add your answer
Rika will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 4,294
