Computer won't start up. Power supply seems fine. Logic board?
Pretty sure from previous posts, but I took off the back cover and only the 1st led is glowing. Other leds never even flicker. No response to internal start and SMU buttons. Capacitors look fine to visual inspection.
Should I still suspect a bad logic board???
Comments:
Anyone out there? Looking for some advice before I drop $200 on a logic board.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
These iMacs suffered from an industry wide problem of bad capacitors. Both on the Power Supply and the main logic board.
Removing the cover will enable you to see the caps on the logic board. you'll see if any are bulging or blown. That'll be your first clue!
Score 2
Comments:
+ agreed, there are lots of posts on this site about this. Just do a search for "bad caps".
by
Add a comment
LED2 indicates that the main logic board has detected proper power from the power supply. Replace the power supply.
Score 1
Add a comment
Add your answer
nohav will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,691
