Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Questions View all
Camera replaced several times
Hello,
I've replaced my camera part, the original had a cracked lens but still worked.
1st replacement: non oem part, worked fine but was noisy when focusing and didnt auto focus.
2nd replacement resulted in a camera fail error when opening cam app
3rd replacement, same serial number as the original - caused the device to freeze at boot at the samsung logo.
I've put the original part back in the phone and it's working fine.
Can anyone suggest a direction?
Original Cam part highlighted in photo
2 Comments
I'm confused by the picture. What exactly is the part circled in fed? Neither of the cameras are there
by
Wasn't the best composed photo so tried to highlight it... the original cam part is in the battery space.
by
Add a comment
Chosen Solution
Have you tried booting without the 3rd installed, booting, then install? You'll want to power cycle the natter if this does work. Just to be safe
Score 2
1 Comment:
Hello, I've just tried booting without, then reinstalling. It's still stuck at boot screen. Thanks for the suggestion.
by
Add a comment
When you mean by original having cracked lens, do you mean just the camera still focuses and doesn't have internal dots / not focusing problem?
If this is the case then you simply only need to replace the back camera glass cover. You can buy these online at places like eBay, costs a few bucks and easy to install. (Does not require opening up the phone but at minimum probably just taking off the battery cover.)
Just make sure to clean the broken glass carefully without scratching the lens or getting it in the camera.
I generally use tweezers or a spudger to scrape away the adhesive bonding to the area that holds the rear camera glass cover.
Then inspect the rear camera for any small glass fragments on or near it. If there is any glass fragments around the camera which it moves to focus try cleaning it out as it may cause focusing issues in the future.
Score 1
1 Comment:
Hi Ben, I regret it was the internal lens. The glass cracked and my dad kept it in his pocket with keys, ruining the lens. I didnt realise the camera moved when focusing, this might explain the focusing issue with one of the parts.
by
Add a comment
Try booting into recovery mode and wiping the cache partition. I find this clears up issues that can't be explained.
Score 1
Add a comment
Add your answer
Michael C will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 86
