Android smartphone with a 5.15" 1080p display and a Qualcomm Snapdragon 820 processor. First released in 2016.
Phone not turning on, no leds blinking at all!
My mi 5 was rooted and was installed with aosp rom. I downloaded a battery calibration app, where it was instructed to start calibration and then when the phone switches off it should be charged to a 100 percent. I had unplugged my phone at 97 percent, but I couldn't switch it back on. There were no leds or anything. I also tried to charge it but now it wouldn't show anything . How can I fix it?
Score 12
10 Comments
me too i have the same problème.
by
Hi,
I had a similar problem, my phone turned of and I wasn't able to turn it on, or charging, there wasn't any leds.
I repaired it by opening my phone (very easy) and unpluged an repluged the battery connector.
I think there is a generic default with xiaomi mi5 battery...
Hope it helps !
by
Wow great answer Geoffrey had the same exact problems and followed your advice found a tutorial on how to disassemble a xiomi 5 on you tube opened it unplugged replugger the battery and now it works !!!!!
Thanks again Geoffrey I how you a beer !
by
I have the same problem. Any solution?
by
Dizefurkan,
You can open your phone and unplug then replug the battery connector (you will easily find a tutorial for it), I made this a few times, but I think, it's just a temporarly solution, mine juste completely die after 8th times...
by
Show 5 more comments
Add a comment
Most Helpful Answer
Hope it helps !
by Geoffrey Borelli
Score 1
Add a comment
Hi
Try yo flash marshmallow roms via fastboot or mi flash
1 Comment:
will it work?
by
Add a comment
Add your answer
Fragout Gaming will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 32
All Time: 7,381
