Sterio in my crv
I have a Honda crv 1996 the sterio is not working and satnav think the wires have been messed with I need to no how cables look in back so I can put back properly thanks Kath
@kathangie this should be it for your CR-V
Radio Constant 12V+ Wire: White/Blue
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: N/A
Front Speakers Size: 6 1/2″ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2″ Speakers
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Use a testlight or a multimeter to check this out.
Hi @kathangie
@oldturkey03 is right. Check all those. And make sure that no wires are touching each other. If you aren't very good at fixing things, best buy should be able to help. If you think you can, take some pictures and post them on here so we can further help.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 293
