No heat, slightly different symptoms than others posted.
Hey all. I have been searching everywhere for an answer to this odd set of symptoms:
Last time I used the dryer successfully was to dry a HUGE blanket on the lowest heat setting. It took two cycles of 90 (timed, not auto) cycles. So that thing ran for about three hours throttling on and off at low setting.
I did a regular load of jeans today and set it to "normal" heat. Checked it when it the timer ran out and it was obvious there had been no heat and very minimal drying.
I removed the panel to observe igniter etc and found that there was no action whatsoever, until I turned it to the highest heat level. At that point, the igniter was bright and the flame engaged, but then the flame shut off after about 3 minutes. I can repeat this without it cooling down. Ignition on high heat, flame out after about 3 minutes.
I replaced the entire duct about a year ago and everything seems good there.
Did I probably just weaken the old gas valve solenoids coils after that three-hour run or are there any other probabilities, given the clues? Obviously, the odd part is that it will only fire on the highest heat setting. Igniter does not even glow on any other setting.
I can't find my multi-meter, so I am going to try the coils before delving in deeper. Any help is appreciated!
Score 1
Add a comment
1 Answer
Chosen Solution
Well stated question.
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won’t heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, I recommend that you replace them as a set.
Score 3
4 Comments:
Picking up coils tomorrow as (cross-fingers) the problem. I am so confused though because if the problem was possibly the igniter, why would it only work on the high-heat setting?
by
...and why would it fire only one time then not? Coils, right? Gosh....I don't know.
by
New coils fixed it; I will never understand what that had to do with no igniter on heat settings other than "high" though. It is fixed though, so thanks.
by
UPDATE: After replacing the coils last night, the igniter started working on all heat settings again and I watched it cycle a few times. Tonight I did a load of laundry, and now the dryer will only fire once on all settings, and will fire twice on the highest heat setting....then no more glow and no more fire. What is going on here?
by
Add a comment
Add your answer
Rob Smale will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 174
