Fetch TV Mighty PVR runs very hot
I would love to see a teardown of more PVR's, specifically the Fetch TV Mighty. This unit is so compact that I'm not even sure where to start. Mostly I want open it up, and then improve the cooling.
1 Comment
I have been having many problems with my fetch mighty and also noticed it does seem to run really hot and have reception issues with it and fetch support has told me it requires a stronger signal than normal to operate. When the signal isn’t being received properly other than it being jittery and annoying to try and watch that’s when it seems to have trouble processing anything operations such as when pressing button a on the remote it’s like it freezes or hangs. I have tried removing the antenna when that happens and after 30 seconds or so controls work again so I can do a reset which sometimes helps reception. Already had the box replaced once and the new one has issues again but so far is working better than the last one. The last one was fine when it was new
by Christian Marshall
