Acer Aspire E5-575G-53VG turned off and doesn't boot
Good afternoon! I really hope that you will help me with my problem.
My Acer Aspire E5-575G-53VG yesterday suddenly turned off during operation, the case was slightly warm. The laptop was connected to the network and I noticed that it turned off when the battery was 100% charged. At the same time, all the power indicators were gently extinguished. After some time in the bag, the laptop was very hot - most likely it still worked. Now the laptop does not react to anything, it does not work, the power indicators do not turn on.
Any idea what to do about it? Thank you!
1 Comment
Hi, also have the same problem but when i put in the ac there is a red light showing when i try to turn on the laptop there is also a blue light but it doesnt turn on. What could be the problem
by
Add a comment
1 Answer
Chosen Solution
Hi,
Have you tried to reset the laptop by pressing the reset button located in a pinhole on the underside of the laptop.
Here is an image of where it is.
(This image is taken from the user manual for an Acer Aspire E5 575G so hopefully it is also applicable to your particular model variant)
(click on image to enlarge for better viewing)
Score 3
6 Comments:
Yes, I tried it on the instructions on the site Acer. No results :(
by
Hi
What happens when you just plug in the charger and switch the charger on only, not the laptop? Do you get any lights showing?
What happens if you switch the laptop on with the charger connected and switched on?
by
Hi!
On my charger there are no indicators, so when I connect, I can not see anything.
When I connected the charger to the laptop, I noticed only one effect - the motherboard starts to heat up. Nothing else happens.
by
Hi,
How old is the laptop?
Check the warranty period as written in the warranty statement that came with the laptop. If it is still covered by the warranty follow the instructions as to what to do to get a warranty repair or replacement.
I think that you either have a battery problem or a charging circuit problem on the motherboard.
by
I got a laptop just six months ago :(
Thanks for the help!
by
Show 1 more comment
Add a comment
Add your answer
Артём Соловьёв will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 3,971
