screen flickering after being dropped?!
hi,
my laptop -lenovo z5070- was dropped from a chair into the ground, after that there is two problems.
'''first problem ..the screen brightness is flickering once i touch the laptop
'''when i touch the laptop the screen brightness goes ok,,another touch the brightness goes little bright,another touch goes ok ,and so on
second problem.. screen from the bottom "at task bar in windows exactly" had some dark areas
notice that the screen is not broken..it's ok
i tried to remove the cover and touch the cables in front but no thing changed
i think the cable in the back of screen is the reason of the problem -may be the drop causes disconnect of some slots -
but i didn't try to check it
i need to know
what is the problem ?
how to fix it ?
'''here is a video showing the problem in order to be clear for you
thanks
1 Comment
@oldturkey03 thanks a lot , i will try that
by mustafa gamal
