Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Questions View all
iMac 24" A1225 Optical drive stopped working for no reason
Anyone know what would cause the optical drive on an iMac A1225, which was never abused, to just stop working?
If I insert a CD it just ejects it. It is really frustrating when the computer has never been misused or abused.
Add a comment
1 Answer
Chosen Solution
There are two reasons you can face here the first is the drives head is dirty. You'll need to get a CD/DVD head cleaning kit to clean the head. Sometimes a quick blow of compressed air though the slot can do it but if you haven't cleaned your system out of all of the dust buildup inside that could make things worse! I would follow this IFIXIT guide: iMac Intel 24" EMC 2134 and 2211 Optical Drive Replacement to get the drive out to then clean as well as clean out the rest of the system using a soft paint brush and a can of can'd air.
The other possible issue is the disk you are putting in is not able to be read/write by the drive in your system. The early iMac's 8X SuperDrive 4X double-layer burning (DVD+R DL/DVD & RW/CD-RW) only supported:
  • Writes DVD+R DL discs at up to 4x speed,
  • Writes DVD-R and DVD+R discs at up to 8x speed,
  • Writes DVD-RW at up to 6x and DVD+RW discs at up to 8x speed,
  • Reads DVDs at up to 8x speed, writes CD-R discs at up to 24x speed,
  • Writes CD-RW discs at up to 16x speed, [and] reads CDs at up to 24x speed.
Score 1
Add a comment
Add your answer
Camille Nixon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 199
