2.26 or 2.4 GHz / White plastic unibody enclosure
646 Questions View all
Can't find hard drive
MBP 13" late 2009
replaced with new hard drive
after about 6 months the HD is not recognized
I'll pulled the drive, placed it in a dock
the HD is recognized and mounts
plugged HD back into the MBP but is not recognized
I done this with 2 drives
they both mount on my iMac
placed both drives in the dock
they mount
I optimize one of the drives and do a clean OS 10.10.3 install
I run Tech Tools pro - reports no problems
I run disk utility - no problems
I run Disk Warrior - no problems
I replace the HD in the MBP - the drive is not recognized
I've done command - R but can't access it
Option - D can't access this
Zapped P-RAM
Help.
John
1 Comment
There was no MBP 13" Late 2009 only a mid 2009
The was a Apple MacBook "Core 2 Duo" 2.26 13" (Uni/Late 09) Specs
Identifiers: Late 2009 - MC207LL/A - MacBook6,1 - A1342 - 2350*
by
Add a comment
1 Answer
Chosen Solution
Isn't this one with the hard drive cable? I'd try replacing it if you haven't already. You may also need to install OSX again after doing so.
Bad HDD cables cause data on a hard drive to become corrupt as they cause read and write errors.
Score 2
1 Comment:
This is not one of the ones with the known HD/IR cable issues. But it's the logical solution!
by
Add a comment
Add your answer
john mormando will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 77
