Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
96 Questions View all
Can disconnected earphone ribbon (step 7) be repaired?
I disconnected the earphone ribbon despite warning in step 7. Is there a possibility of repair (I'm guessing it is unlikely any adhesive would work) or replacement of the full mechanism?
Add a comment
1 Answer
Chosen Solution
Yes it's possible to replace it.
Using a magnifying lens you should be able to put the ribbon cable back in, using the magnifying lens to verify the bare metal portions of the ribbon cable are properly seated.
Super glue will work wonderfully, and should not be conductive (I have used some on electronics before).
If it fails, just replace that whole mechanism.
Comments:
Great advice as I too have been scouring the site (and others) looking for that repair. Step 7 is a bit vague for a first timer cracking open an Ipod. A better picture of what it should look like when done properly (or improperly) would be extremely helpful as now I'm looking at another $30 if the super glue doesn't get the job done.
by
Add a comment
Add your answer
bought4me will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,056
