Very slow charging when phone is ON?
I got this phone 2 days ago and the first charge got approximately 2 hours to full charge. And the next time I charge it takes 30 minutes to increase battery by 10%.
When I turn the phone off and charge, it charges at the rate where full charge finishes in 2 hours. What could be the reason? (I did the first charge when the phone is on)
Thanks.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi,
What is the output in mA of the charger you are using? (It will be printed on the charger)?
It may be that the output is insufficient to run the phone as well as charge the battery effectively. At best it might just maintain the battery at its' current charge level or slowly increase the charge.
It might also depend on how much activity is going on in the phone. By this I mean what actions you are doing, (e.g. playing games, watching videos etc) and also what is happening 'behind the scenes', e.g are apps downloading in the background.
You could try turning off the Data Connection to see if this improves the charge rate with the phone still on. (don't know your phone but it is usually found in Home > Settings > Wireless and Networks >more >Mobile Networks > Data Connection. This setting disables the cellular data connection. Be aware that as well as disabling the cellular internet it also disables the phone's MMS feature (texts with videos and pictures) and also the LTE / 4G network phone connection. It does not affect SMS messages or 2G/3G phone calls.
If you need the data connection try disabling the apps in your phone ability to automatically update etc to limit unnecessary data transmission and therefore phone's CPU activity.
Also if you do not require them, turn off the GPS and WiFi / BT as these functions also use a lot of power.
Hopefully this is of some help.
Score 3
Add a comment
Add your answer
Seth Wanasinghe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 3,317
