Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3944 Questions View all
Wifi doesn't connect, antenna or
I got the phone and the wifi wouldn't connect. I unplugged the antenna toward the top of the phone, plugged it back in, and then it worked.
Does it sounds like the antenna is the problem?
How should I fix this?
There's an antenna like piece, and the other piece near the top of the phone that apparently are related to wifi. Which one?!
Score 1
Add a comment
1 Answer
Chosen Solution
I'm not super sure which part you disconnected. Here's the part. You could potentially remove the antennae, clean everything gold with 90% isopropyl alcohol. Nothing lower, and test to see if that takes. Or buy a $2 part. Or I'm trying to think what software solution would be for this...also I mean obviously check different wifi networks
iPhone 6 Top Left Antenna
EDIT: The logic board antennae flex cable?
iPhone 6 Logic Board Antenna Flex Cable
iPhone 6 Logic Board Antenna Flex Cable Image
Product
$14.99
iPhone 6 Top Left Antenna Image
Product
$14.99
Score 5
Comments:
Also, you don't need to make a new answer/question at the bottom. You can just comment, like I did right here
by
I'm pretty sure I unplugged the wifi at antenna flex cable
by
Add a comment
Add your answer
brownkaleb14 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 88
