Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Questions View all
How can I remove a CD stuck in the CD drive
A cd was already in the cd drive and another cd was put in the same cd drive how can i remove them
Score 3
Add a comment
Chosen Solution
Step 1 (if you are truly lucky): Boot up while holding down the trackpad button to eject the CDs.
Step 2: Access the drive itself, remove the cover, and remove the CDs.
Good luck!
Score 3
Add a comment
I have had this problem with a CD with a stick-on label. Answer:stick your finger nail into the CD slot and pry the case up gently at the same time you hit the "eject" button or command- E. Works for me!
Score 2
Add a comment
Add your answer
Gary Chisolm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 4,007
