front wheel is leaking fluid
Sears model 917.28851 lawn tractor my left front wheel started leaking fluid
@wabbal , Donald, Either some one has added some type of fluid in the tire assy to add weight or it could be some kind of tire sealant installed by somebody(some times may be done right in the factory) trying to stop a leak in the tire or a tire to rim bead leak. Regardless it sounds like you now may need a new tire or if hole not too big, install a tube. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 118
