The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3720 Questions View all
backlight bug after screen replacement
i ve replace plenty of 5s 's lcds, and i have this..one classic lcd replacement became backlight not working animation on lcd worksjust without light , everything else works , lcd checked , i thing the bug was while plunging home button . i dont think i was wrong on screws matching , but i m not sure.. i have touch and itunes sync , i try the update restore option already , i dont see any mark under the screws using microscope.. any idea?
Add a comment
1 Answer
Chosen Solution
Did you disconnect the battery when you did the screen replacement? You probably blew the backlight circuit, specifically the backlight filter. If you have the right tools, you could probe the backlight circuit to see if that is the problem.
(Hopefully you already tried another screen!)
If the backlight circuit is blown, this will require a micro-soldering repair.
Score 1
Comments:
are there any details available of how should i check this? i check my security cameras to check where is my fault.. i was replacing the lcd and after i put the plate i check the lcd just before the home button.. and after i have the plug in of home button i have no back light
by
Add a comment
Add your answer
antonili85 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 36
All Time: 229
