Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Questions View all
iPad A1489 Suspected Back-light Fuse, Diode or Filter Replacement?
hi all,
dudes and dudettes
gurus and guruesses
water damaged iPad A1489, so before I invest too much time and
energy I've read all the other posts questions/answers and til now
I've not seen any that apply to this model
powers up and screen remains dark- but can see the apple logo
(with a strong inspection light)
for 3-5 seconds and then shuts off/dark again
suspected back-light fuse, diode or filter
but I'm not that good as to be able to identify on my own
I've done general mild gentle cleaning and I know at some stage
the lcd connector/pins needs to be cleaned thoroughly
so looking for some kind help-
pictures are just for orientation first
will post better specifics as required- hopefully
thanks in advance- kelef
Add a comment
1 Answer
Chosen Solution
It definitely sounds like your backlight circuit is damaged. Typically it's just the filter (ferrite bead L2200) but it can also be the diode (D8228) or the coil (L8225). Ideally you need to probe the filter with a multimeter to see if it has continuity (it should be indistinguishable from a short). If the filter looks good, then test the diode and the coil.
In a worst case scenario, it could be the PMIC but for now focus on the passives.
Depending on your level of skills and the tools you have access to, this is not a repair I would recommend to a beginner. You can do a lot damage to the logic board if you don't know what you are doing. Ideally, you should look for a repair shop that does micro-soldering repairs.
EDIT
Score 4
3 Comments:
hi https://www.ifixit.com/User/1395548/Minh...
thanks for you reply
but I would need a little assistance locating
"the filter (ferrite bead L2200)" and
"the diode (D8228)" or
"the coil (L8225)"
skills level:-
personally I use a DMM on a daily basis-
solder re-caps and repair simple boards/circuits
small component solder and/or hot air mounting
micro- not so much, hence this is pushing my boundaries
been looking for a schematic or posts relevant to this board
for a couple of months now- so more a skills rescue project now
can probably put the board under a bench microscope
when I get time- but if you could help with the
component identification I would be very,
very grateful
by
I've added a boardview to my answer. You will be able to locate the components from there. The schematic is available in the wild if you want to look at the circuit or need to order replacement parts.
by
Does anyone know what gauge of wire i would need to jump from diode to first pin on screen connector
by
Add a comment
Add your answer
Kelef Man will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 2,665
