Chiming but not powering up after Display Assembly replacement
HELP...Ive replace my display assembly on an 09' 15" Macbook Pro after the hinges broke on the original display and it developed vertical lines but no images. I would use an external monitor when I needed to use the machine. Once I had everything put back together, I press the power button...it chimes once but wont power up.
3 Comments
check on the external monitor. @mayer is more useful then i am
by Cameron
Thanks Cameron....I thought to do that but it wont power on to even chk on an external.
by boxx
if it chimes then its working somewhat. Put the old screen back or just remove the screen entirely and test it then. if it doesnt work then do you hear any beep codes?
by Cameron
