Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
282 Questions View all
Phillips # 000 screwdriver did not fit in replacing fan.
I bought the 64 Bit Driver Kit that you sell.
It proceeded to repair the way that you introduce.
in step#9, Phillips # 000 screwdriver did not fit in replacing fan.
I bought a 64bit driver kit, and it says that there is a Phillips # 000 screwdriver.
Any screwdriver inside it could not be repaired.
If I knew in advance that this driver set would not be repairable, I would not have bought it.
I want to hear you opinion.
thank you.
mail : changho.park79@gmail.com
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Thanks for the answer.
but, If you look at step9 of the video you sent,
Red : Four 2.6 mm T5 screws
orange : One 2.4 mm Phillips #000 screw.
I can not find " 2.4 mm Phillips # 000 screw" in 64bit driver kit
Is there a 2.4 mm Phillips # 000 screw in the 64bit driver kit?
Comments:
Yes, there is a #000 screwdriver in that set. If you are missing it, I would recommend contacting iFixit directly here http://help.ifixit.com/category/133-cont...
by
Add a comment
Most Helpful Answer
The 13" Retina 2013 uses T5 screws for the fan, not Phillips #000. This should come in your toolkit.
MacBook Pro 13" Retina Display Late 2013 Fan Replacement
Score 2
Add a comment
Add your answer
park changho will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 36
