The home base for Android phones.
19582 Questions View all
Touch Glass popping up in Sony Z3, only at top-right corner
How to re-fix the touch glass of my Sony-Z3 which is popping up only at right-top corner without dismantling ? I mean can I glue it and if yes what kind of glue should I use
Add a comment
1 Answer
Chosen Solution
Hi harshaqdc
The problem with this phone is the weakness of the mid chassis down the side that you mention, for a satisfactory repair to be carried out the phone needs to be dismantled and the chassis adjusted this is the usual cause of the screen popping at the corner you mention.
All parts are available for this repair
However if the distortion is only minor you may get away with using a suitable adhesive such as Zhanlida B-600
Use the adhesive sparingly and apply with a fine spatula especially near the LCD don't worry about the adhesive setting off quickly there is sufficient time to apply the adhesive.
Use paper clamps plus a support strip to spread the pressure evenly down the side of the screen and leave for 24 hrs with the clamps in place.
Alternatively with careful use of a heat gun apply heat to the affected area and clamp as described above.
Hope this is of assistance
Neil
ifixsmartphones100@gmail.com
Score 1
Comments:
Thanks Neil. I hope it will work. Will give it a try. Harsha
by
Add a comment
Add your answer
harshaqdc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 14
