Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Questions View all
Question Closed
a solution for head phone removal jack,enlodged in i-pod
I had purchased generic brand of i-pod speakers,and come to realize that when I removed the jack from the i-pod,that half of the jack stayed inside my i-pod,rendering it useless for hearing priv ilidges.Can't plug anything into the dam i-pod.
Add a comment
1 Answer
Chosen Solution
Hi Douglas, so the plug from the speakers broke off inside the jack? Did it break of flush with it or is it deeper inside the jack? If it is broke off not much deeper than the jack you could try to remove it with some very small forceps, tweezers, if you can get your hand on those. The other thing I have done before was using the superglue trick that is normally reserved for small stripped screws. I use a slightly smaller piece of metallic rod and superglue it to the end of the broken jack, then once it dries I just pulled it out slowly. 99% of the time this works. Word of caution, do not use to much, you don,t want to clog up your jack. If everything else fails, you might just have to replace the jack. I know it say i-pod 30gb on the description but if it is the iPod video it it inexpensive and relatively easy to change. iPod 5th Generation (Video) Headphone Jack & Hold Switch Replacement Good Luck.
Score 4
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 656
