Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
229 Questions View all
HELP! My Adata Hard Disk cannot be detected through my laptop at all..
HELP! My Adata Hard Disk cannot be detected through my laptop at all...I know it is obviously dead but is there anyway to retrieve all of the data in my hard disk? It make a clicking sound for a few second... then it dies down. Is there anyway or anyone can help me with this?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
The click usually indicates a stuck head . If you dont have the means to pay for recovery you can try this video You may want to first remove the hard drive from the enclosure and use a SATA to USB adaptor like this to test to see if the problem was not the enclosure itself . Be ready to back up all info if you do get the drive running because any failed drive is never a drive to be trusted again . Hope this helps
Score 4
Add a comment
Sorry to say, but when a HDD is plugged in and clicks for a few seconds then stops it means that some part of the drive hardware has failed.
You can try taking the drive out of the enclosure and plugging into a computer via sata and try some data recovery software. But I'd hazard to guess it wouldn't produce results.
The only option then that I could advise would be to send the drive off to a local data recovery service.
Score 3
Comments:
So...basically it's dead. And my chance to recover my data is low or there is a possibility? I've heard the freezer method technique...I almost kinda want to try it but somehow I'm skeptical about this too...
I never actually never been to a local data recovery service since this is the first time I've encounter this issues. I did ask a company that offered this service and they charged around $2 to $4k is that normal for that charge within the price range.
by
Add a comment
Add your answer
Ekka Kaharuddin will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 42
Past 30 Days: 166
All Time: 397
