Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
if I unplugged the battery and leave it for a while , does it drain?
Hello guys
i left an iphone with new battery for while ( 1-2 months ) and now when i try to turn it on it didn't work , the battery was unplugged for the whole time
when i connected the voltmeter to the battery it shows me the battery has 0 volts
so does the battery drain if you leave it unplugged ?
help me explain this please , and how to avoid it
thanks
Add a comment
1 Answer
Chosen Solution
A Li-Ion battery or any battery will always slowly discharge, whether it is plugged in or not.
In the case of a Li-Ion battery (iPhone battery), it needs to be exercised. It needs to be frequently charged/discharged, otherwise its overall capacity diminishes more quickly.
Score 2
4 Comments:
Also if a battery is left not plugged in or used for a long time it will drain to flat and take a very long time to charge like 30 minutes to get the phone to at least turn on.
by
Correct, so I should add, as @benjamen50 said above. On a regularly used iPhone, 0% isn't really empty. There is actually a reserve percentage that allows the phone to be quickly revived. However, the phone if left completely unused, the reserve will drain, which is why it takes much longer to revive the phone.
by
thanks for your feedback
i just want to ask , how the batteries in stores work then if it discharge while its packed ?
by
Batteries in stores have "Expiration dates" or "Use by" dates. They do discharge, and need to be used by a certain time, or else they are no longer any good.
by
Add a comment
Add your answer
Hesham Adwan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 185
