Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
3653 Questions View all
do I need the icon apple figure to show when I turn computer on
I don't have my figure of the apple in the upper left hand corner when i turn on the computer. How do I get it back. I can get into computer using internet connection and then the apple icon comes on. Do I need to get computer fixed?
Add a comment
1 Answer
Chosen Solution
This would definitely appear to be a software problem. First, I'd check for any software updates available for your unit. That could resolve the issue.
Second, you could try rebooting your computer, holding down the shift key on the keyboard once you hear the startup chime. This will boot the computer into safe mode, bypassing any third party software that may be contributing to the issue.
If the problem persists, you will probably need to reinstall your operating system.
If booting into safe mode resolves your problem, you'll need to troubleshoot what software is causing your issue. I usually start by looking for suspicious third party software in the following locations:
/Library/LaunchAgents
/Library/LaunchDaemons
/Library/StartupItems
~/Library/LaunchAgents
~/Library/LaunchDaemons
Score 1
Add a comment
Add your answer
eraindance will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 58
