LED lighting is not working on the interior of the refrigerator
Everything else is working just not the led lighting in the refridgerator, freezer lights work
Update (03/30/2017)
This is the one I have http://www.searsoutlet.com/26-7-cu-ft-Fr...
Thanks for your help
Score 1
Add a comment
Chosen Solution
@lgabaldon check to see if this model has the transformer in the compressor compartment. If so check the circuit
need to get around 36VDC on those LED lines.
If it does not then check the circuit described here. Voltage for that is 12V
As for the location of the switch, check the area on the top left
Comments:
Yes this looks more like it might be a little too technical for me I'll ask my son for help thank you so much I appreciate your time and help
by
Add a comment
@lgabaldon, Check the light switch to see if it is stuck in. Pull the light switch out see if connection are good, if OK tests with a multimeter to see if it's making and breaking continuity. If the switch checks good, the main control board of the refrigerator may need to be replaced . The links below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=5uBEqxUq...
https://www.youtube.com/watch?v=2juGyjXF...
https://www.youtube.com/watch?v=WTewh4hk...
Comments:
The model I have doesn't have a light switch or I can't find it thanks for responding
by
this model#GFE27GSDSS may be missing one letter. Maybe take another look as there should be a switch maybe different location then above links and the switch should look like the one in the link below, could be located in either upper lower corner face frame of cabinet or perhaps on inner wall where door would close on it.
https://www.repairclinic.com/PartDetail/...
by
Add a comment
Add your answer
lgabaldon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 35
