Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
Connector wont re-attach (replaced screen)
I replaced my screen and now the number two cable wont re connect... number 1 and 3 do just fine. it doesn't appear that the connectors on either end are damaged. what do i do?
Score 1
Comments:
Just a quick question to make sure. The replacement screen was 3G for sure, right? I have a little concern that you may have a 3Gs screen. I may be way off here but let me us know....Thanks and good luck
by
I think oldturkey is on the money...sounds like the wrong screen. count the pins on each part of the connection or check your order. have had this happen before!
the parts are identical to look at, but the connection is completely different and will not fit
by
Add a comment
Chosen Solution
Look on the #2 ribbon cable, if the number is 821-0766-A, this is a 3GS screen.
The 3G screen will have 821-0621-A for the part number.
Score 1
Add a comment
You definitely have the wrong part, the correct part can be found here.
Add a comment
It's very bad as there are lots of tutorials out there on line that say that screens are compatible. Vendors do that too. Sucks!
Add a comment
Add your answer
lucas crider will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,163
