CA CV power supply Voltage output
Hi,
Recently I ordered a power supply 30 volts 5 amps.
I wanted to test the voltage with a voltmeter so if I put it on 5 volts the voltmeter starts at about 6.5 volts and just keeps going up little by little.
So I figured it's defective, I ordered another one from another company different model and it seems to be doing the same thing.
Any input on this anybody?
Update (03/28/2017)
Here are the units I'm talking about. Thank you in advance.
Update (03/28/2017)
2 Comments
@chillsmaker I am a bit confused by that. It is a variable voltage supply? Multiple settings? You are using an external voltmeter to measure the output? Which voltmeter starts a 6.5V?
by oldturkey03
They are Variable Adjustable. So lets say I set the Power Supply to output 5V and I measure it with a voltmeter...the measuring volt meter measures 6.5V and it keeps going up slowly to about 8-9 Volts.
by Asher
