Kenmore Washer agitates and washes just fine but won't spin
If i grab the washer and rock it a few times, then it spins.
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Check your timer
The contacts in timer get bad and wear out.a slight movement of dial could make themjoin together or have contact
It could be your motor in some cases.you have a 2 speed motor.one speed say turns clockwise for it to agitate then the other speed would turn counterclockwise for it to spin.you can test the motor by removing it .letting it sit on floor with the wiring still attached then go to yourspin cycle on timer and see if it turns
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 87
All Time: 8,742
