Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2687 Questions View all
Display spoil after refurbish lcd.
Hello, recently when I'm doing refurbish 6s/6s Plus LCD I found out that everytime I done cleaning the oca on the LCD after removed the polarizer then the ribbon spoil. I found it when I'm doing the last check before put into the machine. The problem is when I touch the LCD ribbon or trying to flip gently the display gone strange. I was wondering is it the oca remover caused it or the static. Please help!
Update (03/27/2017)
This is the problem when you touch the flex or flip it.
Score 1
4 Comments
If the problem not serious the LCD still usable.
by
What does the LCD look like exactly? Can you post a photo? When you remove the polarizer the static line at the top is usually also removed. Which causes a ghosting effect until it is re-applied later in the refurb process
by
Question updated. Is this what you called it ghosting effect?
by
I used 8333 and zippo to clean the oca glue after removed the polarizer.
by
Add a comment
1 Answer
Chosen Solution
You are better off posting this in the iFixit Pro Talk forum where pretty much business owners and etc talk to each other. There are many good LCD refurbishers on that forum that go in depth about these issues and the solutions to them.
https://talk.ifixit.com/
Score 2
Add a comment
Add your answer
Ong Kim Sheng will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 147
